Schedule a Wyze switch
Can someone tell me if there is a way to SCHEDULE a Wyze switch other than by RULE, but rather a local schedule ?
The Wyze switch has a schedule option similar to the plug.
If you go into the switch settings you will see an option for schedules
@R.Good
Thanks for your reply about scheduling my switches. Can’t believe I didn’t find it since I’ve been scheduling plugs for a long time, but was looking in the wrong place because I had them in a group I guess.
For sure, the group settings get me from time to time as well. Especially the bulbs :smiley: … I have to make sure the :nerd_face: are on extra tight.
@R.Good
Now I’m having the same problem finding a place to add schedules “not rules” to the Wyze lightbulbs. Looks to me like you can only do rules and not create schedules for local devices for Wyze lightbulbs. Am I correct?
Yea, the bulbs are different.
You would have to use a rule here.
You could create a rule that tells your bulbs to follow the Plug/Switch schedule.
When plug X is on turn on bulb x and vice versa, but it would not be local.
