Hi all,
I’m trying to figure out how to shut off the wyze plug via schedule for the following times:
1 AM to shut off and turns on again at 6 AM on the same day.
I simply cannot get this to work. Any ideas?
Thanks!
Hi all,
Thanks!
Try using the local schedules inside the plugs settings. Make sure you disable any rules you created to avoid conflicts.
You should be able to set a start time (when it turns on) and an end time (when it turns off) in local schedules.
OP can try reversing the start/stop times and the action. Off at 1am then on at 6am.
It should. Only difference is it is server initiated rather than local plug schedule. Six of one…
I missed that original question was about schedules rather than rules.
No worries. It is a great alternative and valid suggestion if the schedules don’t succeed. Having options is good.
Hey SlabSlayer, thank you very much. I’ll give this a try. I think the issue I had is it’s the same day that it turns off at 1am and then back on at 6am. Either way, I’ll let you all know if this works.
Thanks again.
Happy to help.
Theoretically, the schedule you had shouldn’t matter and should work. The two commands are executed from different command lines, unlike the rule that triggers on start and then reverses the trigger at an end time. Your schedule should turn the lights off at 1am and then back on at 6am.
They have recently updated firmware on the plugs to improve resident scheduling. What version of the firmware is your plug running?
@SlabSlayer
The indoor plug firmware is still on 1.2.0.206, which was released May 11, 2022, but the outdoor plug firmware was updated Nov 7, 2022.
Are you referring to the indoor plug firmware that is still in beta, but has not been released yet?
FW 1.2.0.206 is the current production firmware for Wyze Plug CFH 2021. ẞ FW 1.2.0.233 is the current Beta in testing for the CFH 2021 plugs that has not been released as of yet.
However, FW 1.2.0.236 is the current production FW for Wyze Plug CFH 2022 and was the version I was referencing.
Hey SlabSlayer, thank you so much again for your help. I’ve clicked on your post above as providing a solution.
My firmware version is 12.0.206. All of the statuses in “Firmware Update” is showing “Up to Date” also.
Thanks again. Very much appreicative of your valueable insight and suggestions.
Best to you my friend.
@SlabSlayer
Oops - I forgot about the 2022 plugs, and assumed it was the 2021 plug, but I now see that no specific version was mention in this thread - sorry about that.
I am anxious for the 1.2.0.233 release - I have 10 2021 plugs on 1.2.0.206 with the local schedule issue.
For all beta testers, please test faster! ![]()
Glad that it worked. As you have likely read above, there are others awaiting the release of the Beta FW to fix the scheduling issues.
Hopefully Wyze will release that soon.
HAPPY NEW YEAR
GIFT FOR YOU!
I am so excited to apply this new firmware version! Thanks to the wyze team, and to all beta testers that have been involved.
I am remote from my devices for a few days, but I will try this when I return.
I have applied this new firmware to all of my indoor plugs, some from the individual Device Info > Firmware page, and some from the Account > Firmware page, and they all installed with no issues, without cutting power to their attached devices (whether they were in the ON or the OFF state).
I have tested the local schedule on the original plug where I discovered and reported this one-day-off issue, and it now works properly and runs on the proper day of the week. I no longer need to mentally adjust the days in the local schedules in order to get them to run on the proper days.
Great work everyone, and thank you for the work and the testing involved to fix this issue.
