Safari cannot open page
I’ve never had problem with logging in to the WYZE app until about 3 weeks ago. I have deleted the app. And went through the troubleshooting steps from the site. Nothing has fixed the issues. I can view my camera from the webpage but not the app. This is the error from the app when I log in. Safari cannot open the page because the address is invalid.
Have you tried using another browser?
I know Apple has been making some changes which could affect using safari.
I would try edge or chrome, just to test.
If it works in those, then it could be a security setting or possibly a blocker.
  • What app version are you using
  • What type of device are you using
I have no problem viewing the cams when I go to in safari when I go to WYZE.com and click access my cams. It’s only when I open the app and login I get that error and since it’s the app, you can’t designate another web browser to use. Also, I’m getting this error on my iPad when I try to log into the app. This is on Wi-Fi and cellular. Iphone 15 pro max iOS 18.4 WYZE app ver 3.4.0.11
Yes you can. Go to Settings>Apps>Default Apps and select it there. You have to install Chrome or Edge first.
