Make sure you’re running the latest release wyze app too (in addition to making sure you have the latest release firmware already mentioned in this thread).
You need 3.11.x app to work with the latest firmware.
It’s the V3. I wasn’t able to type in my own tags, I had to choose from a drop down menu and didn’t notice it said Cam Pan v3
Camera 4.36.16.6114 App v3.11.6 (765)
I printed them out and am working through them. I did create an API key
No luck there yet. I’ve tried it with the RTSP address and adding my user name and password before the RTSP address. I’m using the secure RTSP
5. I’ll check the firewall
Thank you for this help. It really helped me
I’m using OBS studio on my PC. I tried to download it to my Android tablet, but what I found in the Play Store didn’t seem to be it
Thanks for the info. I changed it to reflect your use of Cam v3.
That’s not necessary just to get access to the RTSP stream, but you might get other benefits from that. I’ve never created one because I haven’t had a use for it, and I’ve been able to stream via RTSP into several different PC-based applications.
I’d try to get VLC working with regular RTSP first. Once you can do that and have it streaming, then you can see if you can get the proper URL working in OBS without mucking with the firewall. If you can stream into VLC but not OBS, then look at the firewall. That’s how I’d approach it (essentially what I did).
Nice! I saw your pre-edit post before you got it working on YouTube, so I bookmarked it to return to later. Good to know you got it working!
It’s funny that this is what you’re streaming, because when I was thinking about an example that I might actually consider streaming on YouTube, this is exactly what came to mind.
I have a wyze cam on mine right now too, but just to monitor to make sure mom comes back. Neighbor’s dog got one of them last night and had to box the nest in to protect the other 3.
Other than that its a pretty boring view at this point, just a mound of grass. It was in the 20s here last night, hopefully there’s still life in there. She’s due for the first feed sometime overnight tonight, fingers crossed.
They’re a pain and a nuisance on my plants and shrubs but I grew up with a pet rabbit so it is hard to hate them.
I’m sure you know but be aware that like 1 in 10 at best survive, usually the nest gets raided by something (may not want to see that you youtube). I guess that’s why they each have like 30 a year.
I have lawn chairs around the nest to discourage our 70 pound Goldendoodle from getting to the nest.
There was a third. I ran my mower right over the nest, not knowing it was there. The late rabbit was laying on his back and squirming a lot. I didn’t see any blood.
Yeah around here if they make it past the mowers and dogs (no mowers yet, too early in the season right now) the coyotes, foxes, cats, racoons, etc get them. Even saw a possum raid a nest once and they’re not supposed to eat living things…..
I have 4.36.16.6114 and tried setting up both RTSP and RTSPS for three of my V3s, but can’t seem to open them on VLC at all. Has anyone got this working on a Mac?
If you’re just trying to stream to VLC, then I’d stick to RTSP only. If that’s failing even when you follow Wyze’s instructions for testing with VLC (it’s all on that page linked in the quote above), then feel free to post details about any errors you’re seeing.
