I just bought a Wyze Cam V3 and integrated it with Home Assistant (without using the bridge)
But half of the time the camera is unavailable, displaying errors like “levelLoadTimeOut” or “fragLoadTimeOut” or just “Error starting stream, see logs for details” (and I can’t find anything in the logs).
The only way to fix the issue is to wait a while and force refresh the dashboard.
I’m pretty sure it’s not a network issue. I have a mesh covering the entire house (Eero Pro Wifi 6) with no dead-zone
If this was mostly in the last 2 days, there was an oauth issue Wyze was working on. If it’s been longer than that, maybe someone else who uses the cams in RTSP and Home assistant can chime in. What plugin are you using through home assistant for this?
I bought a couple of Wyze v3 cams but run it to Frigate and then to Home Assistant. I can confirm that the Wyze to Frigate connection remains consistent, but the Home Assistant dashboards showing the stream from Frigate are getting similar issues and require a dashboard refresh. I haven’t found good examples of similar error reports, but it doesn’t seem like the HA dashboard is retrying the stream or tracking that the connection is up.
