Curious - how are the cameras sticking to the rock and walls in Wyze photos?
Without a better description (or better yet, link to pictures), we can only guess what you are talking about.
There are lots ways to get a Wyze camera attached to a wall. I have one that has a drywall screw through the base to hold it to my garage. Another is using the metal disk that comes with the camera stuck to the glass of my windshield in my pickup truck and the camera magnet holds onto that… You could drill a hole in the metal disk and screw that to lots of surfaces or use epoxy to hold the metal disk in place.
Does that help?
Thanks.
Photos seen here…
Probably screws drilled into each surface.
