Wvod1 wireless camera mounting
I have the wyze cam outdoor wireless. Wvod1b1. I live in an apartment with cheap vinyl siding. What can I use to attach without leaving holes?
Mod Edit]: Your post was merged to this category since it involves a question and not a request for a Product or Service enhancement by Wyze.
Welcome to the Wyze community @peters4505!
You could use some double sided tape to to this, but I wouldn’t because it’s most likely not strong enough.
The camera has a tripod screw mount on it witch allows you to use any mount with the screw.
A mount like this might work:
I’m not sure how these screw adapters would work, but maybe a solution:
Thanks for suggestions. I found a square piece of wood to attach the camera mount to and then siding clip is attached to that. It actually was sold on Amazon so I’m hopeful. I saw the screw in adapter but it didn’t mention my model.
The little clips are great and they hold surprisingly well. They work with almost anything. You’re not going to get more than two points held though.
