Wyze Cam Outdoor mounting
So I have the wyze outdoor cam however my apartment won’t allow me to mount it using a screw is there any recommended 3M tape etc for this that y’all are aware of?
What type of material are you mounting to?
Either some siding or the wooden door frame
Vinyl siding hooks on Amazon. Very cheap and secure. You will need to get different screws to mount the base to the hook. Also very cheap at Home Depot or Lowe’s. The provided screws are too big for the base. I bought bolts rather than screws that are the same size as those that came with the base and used a nut on the back to tighten it down. Been up for months now with no problems.
Awesome thank you!
