Can’t find them anywhere…?
As far as I know,? Wyze is not currently selling the mounts separately. However, there are mounts for cams available on Amazon which will work with the screw mount on the cam.
From the WOC description:
With the included mounting base, you can mount the camera in either a wall-mount or ceiling-mount position. The camera and the mounting base are connected using magnets. Alternatively, the camera also has a standard 1/4-20 screw hole at the bottom and you can use any compatible 3rd-party mounting kit.
Something like this will work for wall mounting:
