Can I buy an extra mount with magnet for Wyze Outdoor Camera?
Would like to have set up in two places for my Outdoor Cam and be able to simply move Cam between the two locations. Can’t seem to find availability or pricing for an extra mount with magnet anywhere online.
You won’t find any for sale on Wyze. I have 2 of these on my out door cams, The cam screws onto the threaded shaft. It is actually more adjustable than the original magnetic mount. You can find some made by other firms also that do the same thing.
https://www.amazon.com/FastSnail-Adjustable-Security-Interface-Standard/dp/B07DLXWMCV/ref=sr_1_6?dchild=1&gclid=Cj0KCQjwktKFBhCkARIsAJeDT0hVq6gOyOldXU5brLnTuvDjS20z_W0dHupfoNuHgzVqxwVf_zxqfA8aArWoEALw_wcB&hvadid=282846452143&hvdev=c&hvlocphy=1024403&hvnetw=g&hvqmt=e&hvrand=9148423354092951551&hvtargid=kwd-539751557477&hydadcr=14856_9705263&keywords=wyze+mounting+kit&qid=1622484642&sr=8-6
Many thanks, Antonius. Looks like just what I need. Thanks for responding.
Denis
There are a couple other makers on Amazon that sell the same or very similar item. Mine came from Wasserstein.
Thanks! Located them on Amazon. A few varieties. Very helpful.
