I really appreciate all the info so I did click on that direct link and it says that it has expired
No problem, I checked and got the same message but noticed that if you follow the rest of the instructions, it should still work:
I thank you for all your help when I did read again there was a thing that said if it doesn’t download click here then it gives me an option to save to download or my SD card is this going to be the app because it feels like it’s a PDF
As long as you clicked the correct download button that I showed above, it should be the app, not a PDF. If you get something other than an .apk file which is an app installation file, then it means you may have clicked on an ad instead.
I saved an APK copy of v2.5 before installing v3.0, like this:
I ran it through:
for security’s sake, and uploaded it here:
https://send.tresorit.com/a#lwuTmDeWDWM3P3H9FV398Q
from where it can be downloaded securely up to ten times through Sept 19.
Let me know if it works for you. ![]()
when I download this am I downloading an app that helps me send files or is it actually the WYZE 2.5 app
The Wyze App 2.50.9 APK (Android Package) file for ‘sideload’ installation.
I am computer stupid lol I downloaded it went to install it it said oops something went wrong it didn’t install I apologize for struggling
Hi cowgirl’!
No worries. Did you uninstall v3.0 first? It might be as simple as that.
Here’s a sideload primer as well:
https://www.howtogeek.com/313433/how-to-sideload-apps-on-android/
When 2.5’s successfully installed, do this:
to prevent it being auto-updated to 3.0 again.
UPDATE:
Better to use carver’s source upthread:
My method is succeeding erratically if at all.
New app suks!
just download it and google how to install and APK on my phone.
