Replace V3 camera with a V4
I will replace my V3 camera with a V4, and use the V3 in a different location. I’m using the Wyze lamp socket to power both. I’ve got the Wyze SDHC card for both cameras. I currently have Cam Plus on the one existing camera. Is there anything special I need to do to have them both work? The Cam Plus is just for one camera, so can I do Cam Plus on the 2nd camera also or am I forced to go for the expensive Cam Unlimited?
I’m a novice at this and could use the guidance. Thanks!
If I understand what you are asking, you can purchase another single CamPlus subsription (either monthly or annual) for your second camera. It takes a few more cameras to make CamPlus Unlimited the better choice.
