Repairing dropped outdoor camera
I dropped my outdoor camera and now it just shows zero battery power. When I plug in the charger the charge light comes on solid and battery charge never goes over zero. Any way to take the unit apart and look for lose connections?
Search YouTube for disassembly videos for your model of Wyze cam
You can take it apart, battery pack is probably unplugged or the wires broken. Screws are on the bottom after you remove bottom plate.
Took it apart and reseated several cables , now working fine. Thanks
This thread may be helpful.
I dropped my wyze cam pan v3, and the camera cube popped off the side brace. I can’t seem to pop it back on. Is there a trick to getting it back on. Nothing is cracked or broken.
Here is a Cam Pan v3 TearDown video. Once you see how to take it apart, assembly should be the reverse.
Thanks StevenA, I watched that video before I posted, but they show him prying the brace off, but I can’t just push it back on. There is a screw that holds the brace, but not the camera. It just pops on and off. Thanks for your help tho.
