Remove indoor light reflections - Polarizing filter wanted
Remove indoor light reflections.
I have a Wyze cam v3 pro.
I have the camera indoors facing out close to the window with solid white 1" high miniblinds & light curtains behind. For support I use a gooseneck with 1/4" bolt for the camera. The other end has a spring clamp used on the miniblind top headrail.
Flexible Clamp Mount for Wyze Cam
I also added a Zeadio Tripod Mini Ball Head, with 1/4" 3/8" Screw Ball Head Tripod Mount for Cameras ( to adjust angle and rotate precisely)
I have attached to the camera a Wyze Window Mount (black rubber shield). It cannot be flush to the window as the camera needs to point downward so…
I built a 6" wide rectangular box out of construction paper and thin cardboard to block almost all the reflections. Not really a professional look…
Questions: Is there a polarize filter add-on for the Wyze cameras?
Will there be one?
Google: polarizing filter to remove reflections
Click on Images to see the results of a filter.
