TIP - Get rid of light reflections
I have a Wyze Cam pro 3 camera and it is indoors facing out thru a window. At night I would get reflections from the indoor lights around the 4 corners of the screen.
My window has horizontal blinds and curtains.
The fix for the reflection was simple. Take a piece of paper as I did from my printer and cut a strip out that when you bend it and tape, will wrap around the camera.
Adjust so it is flush with the window.
No more reflections.
I have the IR off and no spotlight on.
It is the indoor lighting like my lamp that creates the reflections off the window.
I use a window mount with suction cups. It allows me to adjust the camera position. I also have the Wyze Window Mount.
v3 Wyze Compatible Secure Suction Mount
