When I move the base station to a different location, it doesn’t seem to move on the map after the vacuum runs. Is there a way to move it in the map?
Welcome to the forum @Dookie.
When you relocate the base station you are required to remap your area (or you could do a second map with the multifloor function). The Wyze reboot vacuum will identify the location of the base at that time. Relatively short process with the quick map function.
