Register device?
Hi all,
One of my cams failed to connect and I couldn’t get it going, so I deleted it and re-created it.
Now it’s working again.
I seem to recall I needed to register it, I think somewhere in my account, before it would send notifications or something.
I can’t find where to do that.
Actually I can’t find any of my other devices there, so maybe it’s no longer required?
Thanks.
I don’t think there’s a need to register a device. Once it’s listed in the app, Wyze already knows about it and its owner’s contact email.
That’s for CamPlus. If you have Unlimited, the camera is automatically added.
Also, if you going to do setup on an existing camera, do not delete it first. That way all the settings etc will be retained.
Ok thanks guys.
I do remember though needing to add it to some list in my account at one time, maybe a couple years ago… that was for the free version.
Can’t find it now though, so I guess they removed that.
This is from the my.wyze.com website for CamPlus LIte where you assign cameras:
Yes! That’s what I was remembering. But I can’t find CamPlusLite now. Is it discontinued?
And when I go to event recordings and try to enable smart detections/Person, it jumps to CamPlus.
So I assume CamPlusLite is discontinued?
edit: never mind, I found it on the website using my pc. It used to be on the Ipad app.
Thanks WildBill.
2nd edit: Ok, I found it, they buried it in Account/Services.
I guess they don’t really want people seeing it. Understandable.
