Recent events VS Playback
I’m not digging the change of going to recent events only. Is there a way to go back to playback? There are times I want to view other recordings that aren’t always an event, so can’t view them bc it makes me go forward or backward to an event.
I don’t have a v3 but I believe the new interface is similar to the newer cams. If you go to live view then tap “SD Card” that gives you the full SD interface where (if you have continuous recording enabled) you can watch any time you want.
Ok, thank you! I can do it through the SD card like you said.
