I just have a question about this bundle, specifically with the outdoor keypad. I want to retain the manual key and have the keypad available for a pet-sitter. Can the keypad be installed so that that physical key is still usable? The details say yes, the pictures appear to show the keypad in the place of the key slot. So I’m a little confused.
The keypad for the gray Wyze lock (not bolt) is simply wireless with a mount. You can stick it anywhere you want. The keyhole hardware on your current door lock won’t change, you just install the lock on the inside in place of the knob.
I hoped that was the case, but it was worth asking first.
Thanks.
