Push Notifications automatically disabling
I’m having an issue with Push Notifications being automatically turned off without notice. I’ve been very careful not to change any settings in the app (or my O/S) during investigating this.
Yesterday, I opened the app on three separate occasions. I went into Account, Notifications, then Push Notifications. My camera marked as Main was checked as Enabled. This morning, I checked it and as seen in the screenshot, it’s turned off.
I suspected something like this was happening as I’ve found Events captured which I was never notified of. This is a big deal. I need to know immediately if my camera is triggered.
Can anyone suggest a solution?
Were you ever able to find a solution for this? I haven’t ever experienced it (at least not that I know of), so I don’t know of a direct cause or definitive solution, but one thing I’d try is refreshing your profile from Wyze’s servers in case you have corrupt profile data on your mobile device that might be causing this.
This is how I would get a clean copy of my account profile/settings on Android (click/tap to expand):
  1. Clear the in-app cache: From the Wyze app’s home screen, navigate to Account ➜ App Settings ➜ Cache File Size ➜ Clear.
  2. Navigate back one screen to Account and tap Log Out at the bottom.
  3. Swipe the Wyze app out of the running Android apps.
  4. Long-press on the Wyze app’s launcher icon (on the phone’s home screen or wherever you tap to initially open the app) and then tap App info in the pop-up menu.
  5. Tap Force stop on the App info screen (may need to tap OK to confirm) and then tap Storage & cache.
  6. Tap Clear cache and Clear storage on the Storage screen.
  7. Back up one screen (back to App info) and then tap Open and proceed to log back into your Wyze account/app. (Optionally reboot the phone at this step for good measure and then launch the Wyze app after the fresh boot instead of relaunching it immediately from this screen.)
Note: I don’t know what the options would be for modifying these steps on iOS since I don’t use that platform.
How do you exit the page after you have checked the box?
