Temperature Control with reading of remote sensor only
Would be desirable to be able to install the Wyze Thermostat anywhere in the house, even at places where no temperature control is wanted. In order to do that, the Wyze Thermostat needs to work with a Wyze remote sensor but not average the temperature signals. Instead, use only the remote temperature for control.
I would add Include more than one room sensor as primary
I would love the option to be able to include more than one room sensor as primary. Let it do average.
i.e. I have 3 rooms for my 3 babies, each has it’s own room sensor. At night I would like for the HVAC to monitor all 3 of those rooms. But at the same time ignoring other room sensors I have i.e. master-bedroom and living-room.
I cannot install the Wyze Thermostat in my bedroom because there are only two wires connected to the existing thermostat in the bedroom. There is no c-wire. It would be prohibitively costly to install a c-wire from the bedroom to the boiler zone switching relay.
If I could use a Room Sensor as the primary sensor, then I could install the Wyze Thermostat in the boiler room where it would be simple to connect it to the zone switching relay with three wires, including a c-wire. Then I would simply install the Room Sensor in the bedroom. The functional result would be equivalent to installing the Wyze Thermostat in the bedroom.
If I have guests over to watch anything in the TV room (or dinner in the enclosed dinning room, etc…) , I should be able to control the climate in just that room, and ignore the rest of the house. But since my thermostat is in the cold part of the house, I only get an average temperature between the two locations. So I have to constantly chase the temp setting on the thermostat as to not overheat my guests.
It would be nice to be able to open the app, select a specific sensor, and hold the temperature on that sensor and ignore the rest of the house.
