I want to use the base Wyze thermostat with the Wyze remote sensor but only want the base to act on temps from the remote sensor down the hall and not react to the temperature at the base which is in front of a new heat pump fan in the living room. The heat pump blows right on the house baseboard heat thermostat which gives it erroneous readings that are not representative of the rest of the area. Can that be done?
Not at this time. There is a Wishlist item which has been entered to allow for that,
Welcome to the Wyze User Community Forum @rickinny!
Glad to have you aboard!
Here is the wishlist request for that feature. Follow the link, vote at the top, drop some heart
likes on some good posts and add your own post as a reply at the bottom.
