I have two, appliance-grade “smart switches” (another brand, but Google/Alexa compatible) that can turn on/off electric baseboard heaters.
I see that the Wyze thermostat is available with “remote” thermostats so as to monitor multiple room temperatures. Can the Wyze thermostat tell my smart switches to turn those baseboard heaters on/off to maintain a given temperature in a given room with the baseboard heaters? If not, any ideas? Thanks…
I’d like the Wyze thermostat to “read” the remote temperature of a Wyze Room Sensor, and then tell the appropriate smart plug to turn ON or OFF, based on the temperature in that room.
however, at this time, there is no trigger for the remote sensor T-Stat to do this, the only triggers available are the ones listed.
With that said, do you have Wyze’s Home Monitoring System (HMS)? If you do you can use a climate sensor attached to that and then trigger on the following:
Senses the Temperature is above
Senses the Temperature is below
Senses the humidity is above
Senses the humidity is below
So based on this, you could set the action to tirn on the switch when the temp is above a certain temp and the off when the temp is below a certain temp
