I can’t seem to find any way to do the following. I want my wyze thermostat to switch to heat mode and set it to a specific temp if one of my wyze climate sensors go below a specific temp. I want this since my daughter’s room door is shut at night and the thermostat registers a higher temp since it’s upstairs and at the top of the stairs. (Heat rises) so it would be 71 on the thermostat but her room reads 67.
Related topics
Topic | Replies | Views | Activity | |
Wyze Thermostat Alexa Integration and Commands | 10 | 6542 | February 4, 2021 | |
5 degree spread in heating/cooling setting for wyze thermostat | 32 | 7580 | February 2, 2025 | |
Welcome Wyze Thermostat: the simple and affordable way to bring smart heating & cooling to your home - 10/6/20 | 238 | 12764 | December 28, 2020 | |
Please add Alexa integration to the Wyze Climate Sensors | 3 | 709 | April 16, 2023 | |
Provide the ability to use the Room Sensor(s) as the primary sensor or within a primary sensor group and treat the thermostat as an excludable sensor | 34 | 2858 | April 18, 2024 |
