Welcome Wyze Thermostat: the simple and affordable way to bring smart heating & cooling to your home - 10/6/20
Wyze Thermostat is here to shake up the smart thermostat world for only $50. This no-nonsense thermostat makes it super easy to control remotely and keep your home comfortable.
You’re gonna love it.
Great job Wyze! :tada::+1: I beta tested this!
I’ll try to answer questions, but @UserCustomerGwen and @Chuan are** Wyze employees and they can give you the official answers!**
Yup, yup! But the thermostat, sadly, isn’t compatible with my apartment so @Brlepage will have some great hands-on experience to discuss that I don’t have. :slight_smile:
Hi - have been excited for this device but am having trouble understanding “accessory support”. The specs say “one accessory support available”; does that mean that if you have only one “accessory” (say a humidifier) attached to your hvac this unit will be capable of controlling it?
Thanks much!
This yet another engaging product from WYZE ~
looking forward to getting one
Welcome to the Wyze community @TheLogic!
Yes! Each thermostat supports 1 humidifier.
Mine is on order, it didn’t list pre-order, does that mean it will be shipping soon? Sooner than the doorbell?
@UserCustomerGwen what rulled it out for you, baseboard heater?
@steve4335
It does say that it ships December 2020 and that it’s in pre-order.
Thanks, i must have missed that…
Edit: @Brlepage I found what confused me, on my orders page it lists it as “processing” as opposed to “pre-order” for the doorbell…
Great - thanks for the prompt reply!
Will the wyze thermostat be comparable with google home? THE FAQ section said it would work with Alexa but didn’t specifically mentioned google home. Thanks!
Wyze Thermostat…Hmmm I’ll buy and use it spring. Can’t risk it this winter :snowflake: We are expecting temp to hit -65° degree celsius
The installation was pretty easy for me. it heats and cools well too. That’s sounds like a crazy winter! :snowflake: :cold_face:
@steve4335, my system is high voltage so that ruled me right out.
@jfinleyuf, we are working on the Google Assistant integration now but aren’t giving an ETA yet. :slight_smile:
@superchi, that’s a heck of a winter! :grimacing:
Do you know if the external temp/humidity/motion sensor accessory works without the thermostat?
The external sensor would work with a Bluetooth connection and your phone but you wouldn’t be able to use it remotely without the thermostat.
Ahh too bad! I also have high voltage baseboard heating so I can’t use the thermostat.
Maybe a WiFi version or Bluetooth to WiFi bridge would be a good idea.
Or perhaps in the future it could link with a google home or echo device through bluetooth :smiley:
