After one round, voters and commenters seem to favor:
In addition:
And:
Plus some history!
When I first started with my first wyze cam I only had simple dsl with 1.5MB download and who knows how small upload. Things didnât work very well for the cam. Once I upgraded to 100mb service with xfinity, what an improvement(now at 800). Iâve since gone all-in with wyze- I now have 9 cam pans, 2 Battery cam pros, 1 floodlight cam, 12 outdoor cams on 3 base stations, 1 doorbell v2, 2 cam v3, 2 OG, 4 cam v2, 1 switch, 6 plugs, 5 bulbs, 1 watch 47, 1 pr wyze buds. 80% of the time, everything works fine. Occasionally a cam will lose connection. All 6 of the wyze plugs power various cams so I can easily restart the cams when they lose connection. Plugs never have lost connection. My router is a mid level ORBI mesh 860 with 2 nodes. It is wifi6 and very reliable with a node at each end of the house connected by cable. I believe it all comes down to how much speed/bandwidth you have first and foremost. The only thing i wish I could do is specify which device uses which router node. Some of the devices insist on using the furthest node. Otherwise Iâm pretty happy.
Depending what area youâre, your Xfinity upload may still be pretty slow. I know they wanted people to upgrade to gig just to get 50M upload (I think the base plan was 10M and the middle plans were 20M). But if theyâve upgraded you to mid split I think you can get 100M to 200M typically.
Each cam requires about 1mbit/sec of bandwidth but thatâs only while youâre viewing them or theyâre uploading clips for analysis so as long as you arenât watching a bunch at once or having several uploading clips frequently, probably work fine either way.
Iâve been on 300/300 FIOS for like 10 years (well it started at 100/100 and has gotten free upgrades twice). I canât imagine going back to having to worry about upload speeds. Speed tests are always consistent 310 down 350 up. For $25 a month, canât complain.
I am surprised Orbi does have that option. I see and use it on my TP-Link. Speed is nice. I am happy and comfortable on my 100MB dn. Neighborhood fiber is being installed. I donât need more speed but every one wants it.
Hey rick, a blast from the past re that. ![]()
I ran across an informed assertion that âhigh accuracyâ for facial recognition is currently 80%.
Iâm guessing the typical customer expectation is higher. Without any basis Iâm guessing 90-95% (same as tech functionality in general?)
Yuh.
Just last night I dropped from ~90% to 80% or below: Two new routers with big radios are the ants at my picnic, currently (interference.)
It seems to me one of the first questions to ask about WiFi is where do you live?
- Single family home, fairly isolated from neighbors?
- Apartment complex abutting other apartment complexes?
