Playback is not working without any subscription
What model was the other camera? Did that have cam plus lite? That would of allowed 12 second event clips to the cloud for the v3, and any camera that was released before it.
Cam OG is not compatible with Cam Plus Lite. That’s the “non-subscription” that you use for your other (older) cameras. With the OG, you need to install an SD card and record locally, not in the cloud. The good thing about SD card recording, there’s no more cooldown and you’ll record everything.
As others have mentioned your older cams probably have the legacy “Cam Plus Lite”. The OG (and any camera that came out after the v3) does not support that, you either need a subscription or an SD card to get recorded video clips. I use my OGs with SD cards and no subscription and they work great that way.
Got it, thanks. I’ll get a card.
