Password Limitations for Mesh Router
Finally! I had pretty much done everything you said. Multiple times. The key was that the old wifi was still active, so when I would try the re-pair option, the wifi settings never came up. When I turned off the old wifi and tried re-pair again, wif settings came up and now the hub is on the wyze router using the changed password that the wyze router allows.
Thank you for your help!
You’re welcome! Glad it is now cooperating!
