Paper Plane?
What is with that ‘paper plane’ design on the app in order to send in a ‘problem’? It is distracting and will not go away. Checking cameras, the small figure is in the way all the time.
Welcome to the group! Is that the submit a log button? You must be on a beta app. The beta app is available to users to test new features and report issues that are found. I am guessing that button is prevalent so that it’s easy for folks to submit issues. If you don’t want it, an option is to go back to the production app.
Thank you for the fast response. You explained it to me and I am a beta tester and I enjoy being one so now that I understand it better, I am fine with that. Thanks again.
Welcome to the Wyze community @muzikofthenite!
You may also hold down the “submit feedback” button to move it.
Thank you for your help and response.
It doesn’t stay moved though. The next time you open the app it’s back where it started.
Thank you for your response. Yes, I can move it when I need to and when I open the app again, it is back where it started. I just wasn’t certain why it had suddenly appeared, but now that I know, I am fine with that.
