Please make the message notification paper airplane a tab not located in the usage area. You can move the airplane but it goes back to it’s original location the next time the program is opened.
You can actually move that button around the screen. It is a floating button. you can also turn it off by going to Account > App Settings and then turn off the Submit Log Button.
However, it should be noted that the latest App has been officially released on March 8th:
-AND-
This information is found here:
Welcome to the Wyze User Community Forum @vetronec!
The Submit Log Airplane Button does tend to get in the way sometimes.
It is odd, in some Beta versions the button remembers where I last put it, in others it isn’t persistent and always returns to the lower right.
But, as was already suggested, there is also always the option to just disable it and submit logs the same way as the production app thru the Support \ Submit a Log UI.
