Anyone else having the issue?
Wyze App v3.0
Wyze Pan Cam Firmware 4.50.5.0587
Android v14
I am having issues with manually moving the v3s, tapping the navigation button multiple times which should move the cams a limited distance. Instead it causes the cams to rotate all the way the stopping point, or just shy of the privacy mode position, or pointing straight down.
I did have this issue in the previous version of the app.
Anyone else having the issue? Is there anything I can do to repair it?
Thanks in advance.
