The notification from my Solar Pan Cam are running about 4 - 5 minutes late. Any idea how Incan correct this? A 5 minute delay kind of makes that notification useless..
evanskl_00, on the Solar Pan Cam the push often waits until the event clip finishes uploading, so a weak 2.4 GHz link can easily add a few minutes before the phone alert shows up. Open the camera in the app, go to Settings, Device Info, and check the signal (RSSI). If it is worse than about -70 dBm, move the cam closer to a 2.4 GHz access point or mesh node, or add a nearer AP, and see whether the delay shrinks.
Also check whether the event itself appears in the Wyze app timeline at the same lag, or only the phone notification is late. If the app already has the event on time and only the push is slow, look at iPhone Settings > Wyze (Notifications allowed, Background App Refresh on) and turn off Low Power Mode / Focus modes that silence alerts. If both the app event and the push are late together, it is almost certainly the camera uplink, not the phone.
Is this just for the Solar Cam Pan or other cameras as well?
I thought the notification was triggered by the uploaded event image that displays in the notification.
My devices only show a 3 bar Wireless symbol for Signal Strength.
Does the Solar Cam Pan show Signal Strength in dBm?
Try running ‘Reset Services’ (at the bottom of the Settings screen) to re-sync your cameras with WYZE back-end.
