Pan Cam 3 Playback not working
After the latest iPhone Wyze update the playback doesn’t work on Pan Cam v3. When selecting event from the list, nothing happens, when selecting SD Card on the same screen message appears that there is not SD Card when there is one as I can play back from the Camera screen. So frequently when Waze releases an update they break some functionality, so disappointing
Known issue. You can play back events from the list at the bottom of the camera’s live view screen, or go to the SD card from that same screen and play them there.
If you have a subscription, you should be able to play back cloud events tab fine (I believe they auto play in that case).
Thank you for your replay. Known problem? It was fine until the last update. This isn’t the first time an update breaks something else
It’s recently been discussed for Cam Pan v3 and also now appears to affect Cam v2.
