Palm lock cable is to short
I I have recently purchased the Palm lock and have been so excited to install this. Unfortunately I have a door with a large lock mechanism in it. This will work in the door but the cable that goes through the door is about two to three inches to small. I cannot get it to fit. I contact tech support but with the response I got, I felt that they were not interested in my problem. Is there a place I can purchase maybe a 10 pin micro connector ponytail of some sort to make it work? Or does someone have a solution to my problem. Thanks!
Welcome @car1crewchief
you can try Cables.com to see if one is there.
However, how thick is your door? Can you take some pics of the door straight on?
Looks like the Bolt is lower than the opening in the current picture which is puzzling to me.
The door is 1 3/4 wide.
Thanks, interesting door. My in-laws have a similar setup for their double doors out to the driveway area. Interesting that the bolt is lower than the actual lock.
Try Cables.com for an extension cable. However, before you spend anymore money, have you tried connecting the lock without the cable being hooked up to makes sure the lock will work with your setup? Just wanted to make sure. Normally the Wire will go on the bottom on the bolt area and through the plates you put on the door.
I hooked everything up and try to test run with it and it works. The problem I’m finding is you have to go over the top of the lock mechanism then down to the bottom to run the cable through the plate and then back up into the other half of the lock. Just not enough wire. I will though check out the site you recommended. Thank you for your time I appreciate it!
Found these 2 locations…
https://www.amazon.com/s?k=jst-xh+10+pin+connector&channelId=500&clpRedir=Y&plpRedirect=mhFallback
and
