Outdoor V2 Mounting options
Hello,
Outdoor v2 cam.
How can the camera be secured? It looks like it has a magnetic mount. Anyone could easily steal it or knock it down.
Is there some way to secure it?
Thanks
Mark
Get a mount like this and screw the shaft into the threaded hole on the bottom of the camera. Plenty of choices on Amazon and other vendors. I’m using 4 of them. on my V3 cams and also my WCO cams.
While that mount is definitely more secure than a magnet, if someone intends on causing damage to the camera they can easily break the camera or mount.
If you want to keep it safe you just need to put it high up and out of reach
