One alternative:
Pull off the base and expose the threaded hole… Many possibilities.
Good job @VictorErnest
and welcome to the Community Forum! ![]()
I wish this particular mount you have worked with the V3 from what I read it doesn’t fit properly. I am looking for a small mounting bracket to attach outside a window into brick. Yours looks great though !
Look into “brick clips”
Check this guy’s site he makes quality products, prices are very reasonable and he stands behind the products:
https://www.etsy.com/shop/ideaxtruder?ref=simple-shop-header-name&listing_id=788693285
Thanks for sharing my stuff. I don’t however have any camera related mounts. Because of the 3V having a standard screw mount I haven’t found a need that didn’t already have a solution. However if I am missing something please let me know. I just like solving problems.
Just saw an opportunity for recognizing good work.
Very clean looking camera mount.
Nicely done.
