Mounting option for Wyze Pan V3
I have a handful of cameras already and we mount them with adhesive and magnets. We had the v1 pan cam and still do in our window, and just let it sit there with no adhesive and it has been there for a very long time.
We have V3 cams outside but miss the pan option, so just bought two Pan V3. However, when we got the cams they had a screwed on mounting option.
We cannot use that mounting as we have siding and no place to screw in a hole for it. We Already have two V3 cams attached to the outdoor light sockets for power, and just wanted to upgrade a bit.
Does anyone have a mounting option or know if the adhesive mounts will work?
Check etsy.com Lots of siding mounting options, without penetrating your material.
Ive seem some but most of them seem to be for the V3 and not the Pan model
Did you find an option that works for you? I’m looking for a no-drill mount as well and this might work:
https://www.etsy.com/listing/1382841596/wyzecam-pan-v3-vinyl-siding-clip-mount
Agree! They need a mount that uses adhesive/magnet like their V3. We have had those for 2 years and love them. Wanted to upgrade to cover more area only to find my only mounting option was screwing into something. This does not work for us as our house has vinyl siding I am not screwing into that. I am surprised no one has come up with a way to adapt the old mounting brackets to work. You eliminate home owners or renters from using this camera’s by only providing a hard mount option.
You can use vinyl siding mounts that have a 1/4’'-20 threaded stud. I use these that work for all cam models except OG and OG Telephoto:
https://www.amazon.com/HOLACA-Mounting-Weatherproof-Stainless-Material/dp/B092V4C24S/
