Outdoor Power Cable for Wyze Cam V3
Hi, Does anyone know if an outdoor power cable is available for the Wyze Cam V3?
Welcome to the Wyze community @robh0502 !
No information has been released on when of tif the Wyze outdoor adapter will be released.
You can use the included power adapter and an extension cable like this one:
https://www.amazon.com/Power-Extension-Playstation-Classic-Camera/dp/B07GD8CWN4/ref=sr_1_4?crid=1NXHSCM4VSO5E&dchild=1&keywords=outdoor+rated+micro+usb+cable&qid=1612029545&sprefix=Outdoor+rated+micro+%2Celectronics%2C167&sr=8-4
If you need to plug the camera in outside, I’d suggest using an outlet cover like this one:
https://www.amazon.com/dp/B07MHFZHDT/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B07MHFZHDT&pd_rd_w=1CAik&pf_rd_p=14ceaa6a-1e28-4d0f-a108-58cc89c508f1&pd_rd_wg=L2IHJ&pf_rd_r=MWNAW4Y2YWT6G0EQHEKN&pd_rd_r=64baf155-07bc-4896-a3b3-8159d2c5bbcb&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyMzFQV05PSEpRVFhJJmVuY3J5cHRlZElkPUEwMDAzNDAzNzhDRUVYMDNDMEsmZW5jcnlwdGVkQWRJZD1BMDgyODM1NTFPR0JWSzlUWTFHQ04md2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWMmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Edit:
An alternative is to replace the outlet with a model with built-in USB-A ports. Leviton has one. You still need an outlet cover, but it doesn’t have to be as deep to accommodate the power adapter.
https://www.amazon.com/Leviton-T5632-W-Charger-Resistant-Receptacle/dp/B00J3PMU4C/ref=sr_1_4?dchild=1&keywords=leviton+outlet+with+usb&qid=1612033996&sr=8-4
