Does Wyze plan on releasing a outdoor rated power cable /adapter for the cam3 camera ???
Yes, just make sure you get the one that is V3 compatible as there are two versions available.
Thanks for the response
Just to confirm, the Camv3 can be hardwired to a existing outdoor light fixture and I don’t need to plug camera or adaptor into a plug outlet.
Thanks for your help.
That would be something different, that would be the lamp socket.
The camera uses 5 Volts 1 amp, so you need a power adapter like the socket. If you hard wire it to an existing outdoor light at 120 Volts the cam will be toast.
Thank you, you have answered my question…
