Outdoor plug issue
Has the problem where the second plug ignores scheduling programs?
I am tired of using multiple plugs because only the number one socket works with a schedule
If you’re talking about the issue reported here, then I haven’t seen any update:
I haven’t been able to replicate that with any of the Plug Outdoors I’ve tested, and there also hasn’t been a fix-it-friday for a while (though a Wyze Team member has indicated a plan to resume those in January), so I’m not aware of an easy way to track the status of that issue.
If you’re experiencing the failure when you try it with Local Schedules (which are saved to and run from the Plug), then what happens if you instead try running a Schedule-type Automation (which runs from the cloud and, therefore, requires an Internet connection)?
