I brought my Wyze Cam Outdoor inside to charge it today (it was totally dead), and while it was charging, I updated the firmware on the base station. When I turned my camera back on, it wouldn’t connect to the base station. I tried deleting and re-adding the camera, but no luck. I then noticed that the light on the base station was solid blue-flashing blue-solid blue-flashing blue.
The base station is connected via ethernet, FW version 4.16.2.7
Did you update the cam firmware also. Since you can’t get the base to connect try the manual update of firmware to the cam and base and try again.
