Outdoor cam 3 bars. Base station zero bars
I have reset base, camera and wifi. No change. Camera wont work unless within 6 ft of base station. I have fiber op and mesh wifi to cover 5500 sq ft!
Then you have a bad camera go do a warranty replacement at Wyze
Welcome to the forums! How are you connecting the wco base station into your network? Are you using wifi or Ethernet cable? The camera only connects to the base station, but it might be interference from something else, or something between the base and the camera, or base and wifi source if your using wifi with the base. So can your tell us more about how you have everything installed, and what’s between base and camera? Thanks in advance!
