Original Lock Offline
It has been working fine, Then I started getting low battery messages even after installing new Duracels that I checked with a meter. Then I get constant “Offline” staus.
The little lock hub thing is in direct site and less than 10 feet away from the lock. The light is solid green. I’ve unplugged / replugged, held the circle button numerous times. Any idea?
Thank you,
Joey
I deleted the lock and the gateway. Reinstalled the gateway. When I hold the pair button on the lock for 3 seconds nothing happens.
Also, In tried to update firmware on Sense Hub. Update failed twice.
Joey
