Orbs at night
Dust, Ash, Pollen… unless its something that looks like a body floating through the air I’m pretty sure it CAN be explained. Looks like a spider silk floating in the air… doubt your house is haunted.
I had this white shadow come around the corner of my hallway. Any idea what it is? It’s easier to see in the video I have but it won’t let me post it.
image|231x500
@tjc0927 Welcome!
I’ve raised your trust level so you can upload the video now. :slightly_smiling_face:
I’ve also had unexplained shadows on my camera I would like to share but can’t upload.
@bonniecharpie
You should be able to upload now
You guys dismiss these things to much try to explain this if you say bugs I kindly ask you to dismiss yourself camera posted outside on the ground facing up toward sky
I don’t dismiss it that easy. That door is sealed to fight to be a bug. I just don’t have any other explanation.
Tight*
event1623315844000_2CAA8EF1FCDE131623315844
I can’t see your link. I think someone has to raise your trust level, which Idk how to do.
@jcaruso676 I have adjusted your trust level so you can upload more files now.
