Operation failed playback sd card
For anyone that may have camera issues. Keep this in mind. No related to this subject content.
A while back I had a bunch of metallic helium
Balloons located in my living room. It was located between my router and my outdoor v3 camera. The signal strenth showed good on my cam app, but to my surprise it caused my cam to not work properly. As soon as I moved balloons out of path the cams started working properly.
I no longer get Operation Failed on playback after the iOS app update. But I now notice some playback videos seem to pause, and if I jump 15 seconds forward, can get the video to play back.
At least I don’t have to jump back between Continuous and Event Only recording just to view back my videos. Wish there was a response from support before I had wiped out months worth of videos on my SD cards trying to troubleshoot over the past few weeks.
You don’t mention a version?
That said, at first blush (initial testing), beta 2.44.0 (3) was just released and appears to have potentially (and finally) addressed this issue. (Only time will confirm.) If that is the case, the latest release version could have addressed it as well. (Pushed as a quick fix once they knew what the problem was.)
@brian163 Version 2.43.5 (3)
