Has anyone suggested a new feature in the Wyze Cam app to allow for one button enable/disable notifications on all registered cameras?
Clicking into each camera set up page and waiting for them to connect takes a long long time if I have several cameras throughout the house.
Does this feature already exist and I just missed it?
Turning off notifications on all the cameras once I’m home would be fantastic and then when I leave, I can enable all the camera notifications in one button touch.
You can use any available IFTTT trigger to take Wyze actions, not just location. For example, if you have an Android phone, you can trigger actions when your phone connects/disconnects to a specific WiFi or Bluetooth (Android Device triggers). Or with either Android or iOS, you can create a button on your phone to take actions when it’s pressed (Button Widget triggers).
I have 3(three) wyze cam v2. Is possible to turn ON push notification ONE CAMERA only while two others are OFF? I tried turn ON one camera but it turned ON all cameras.
