Hi I just got the OG cam (have 3 V3’s and 3 V4’s). The OG cam says it has motion triggers in the events tab, but when I go to the SD card history in the app, no icons show up for the motion or sound trigger events like the V3/V4. Why does Wyze have different interfaces for each cam? Very annoying.
Known bug with the current version (and past couple versions) of the 3.x app. Hopefully they’ll fix it soon.
I don’t have an answer to this question, though I’d be frustrated by the inconsistency if I had older camera models in my mix. I think Cam v3 was the last of the “old” UI, where models introduced after that have the “new” UI, though even then there are some variations in the on-screen icons and other UI elements between models. I’m using Cam OG (and Telephoto), Cam Pan v3, Cam v4, and Video Doorbell v2, and they’re similar enough that the differences are easy to get accustomed to, but the preferences between “old” and “new” UI seem to be quite polarizing on the Forum.
I think @dave27 alluded to this as a known issue, and you can find more detail in this topic:
I haven’t seen any official acknowledgement from Wyze that this is an issue they’re tracking, but I think the the discussion in that topic provides decent evidence that it’s likely an app problem that could be remediated with an update. If you have the time and inclination, I’d submit a log and open a ticket just to be another incident to let them know that this needs to be on the developers’ radar.
