Offline HELP
After charging the outdoor camera I can’t get it back online.
@roycepsmith Try power cycling the base station unplug then plug it back up. If that doesn’t work turn the switch off/on on the back of the cam. Make sure you give it time to connect. You should see a solid blue LED on the B.S.
Thanks, power cycle didn’t fix it so I’ll have my husband climb up tomorrow and turn it off/on. Thanks
