Notification sound stopped
For the past few weeks my (Android) no longer makes a sound when a camera event is triggered. I hadn’t changed anything in the app or on my phone. Other apps and notification sounds all work as intended.
My partner, who the devices are shared with and is also on Android (later version), doesn’t have the problem..
I get a visual notification, but no alert sound. I did try changing the sound to something else but it makes no difference! Judging by some of the other notification issues reported lately (some, like people getting notifications they hadnt set, are almost the opposite to mine) Something changed. Please fix!
What Device are you using. I had that issue, in the past, which turned out to be the notification sounds Wyze Provided. If you go into your notification area, on your device, you can select a sound from within there.
Note: you will see multiple Categories: Wyze Sound 1, Wyze Sound 2, WyzeMessages, etc. You can go into each one and test the sound and see which of those don’t alert. Then select a new sound provided by the manufacturer of the phone or devices.
Since the visual notification still shows, it might be the Android notification category itself that got switched to Silent, which can happen when an app update recreates its channels. Long press one of the Wyze notifications when it comes in, and it should show whether that category is set to Default/Alerting or Silent. If your phone is on Android 15 or newer, also check Settings > Notifications for Notification cooldown, since that quiets repeated alerts from the same app and could explain it working on your partner’s phone if their settings differ.
TL, DR - Uninstall and Re-install of app worked.
Tx guys for the helpful responses. I was using Android 14 and the latest Wyze app. I checked absolutely EVERYWHERE to see where I could have gone wrong and checked against the settings in my partners phone to make sure they were the same.
In the end I couldn’t pin it to anything so I completely uninstalled the app and re-installed. When starting it up for the first time a banner appeared in the app saying to enable notifications - I did and it brought me to the same Notification settings area I had been in already (and had already had notifications on). I exited and now the app appears to work as intended and I am getting sound notifications again..
So, Basically an uninstall and re-install.
Tx for the suggestions and help…
What was involved in your eventual fix? Did you have to do any setup on the camera itself, or just delete the app and reinstall it?
I deleted the app and re-installed it.
When I logged back in w the new app it re-instated my “favorites” list in the same order it had been in. The only things I noticed was that the app had gone back to “Light” mode and that all the cameras (I have 10) had by default gone back to HD streaming (I prefer 360p as many are on a lower bandwidth 4g modem). Other than that I didnt notice any other “setup” things changing…
I have only one camera (solar cam pan, original) and am getting no notifications on my Android 16 device. I did uninstall and reinstall the app following your instructions to no avail. Do you have any other suggestions?
If you’re not even getting visual notifications (banners, pop ups), it may be an issue with your Detection settings, e.g. the sensitivity slider, or you may have the app set to notify only when certain “smart” events are triggered. This area can be confusing to set up as there are many areas to check. “play around” with it!
Check the “Events” area of your app to make sure that your camera has actually “noticed” events.
If no events are present, it must be the Detection settings, If there are events, try the advice others have given above, paying attention to which notification sounds you assigned to the camera - and also check the “Account” area. I dont know exactly what went wrong w mine, all I know was de-installing and re-installing worked.
Thats all I’ve got!
If the Events tab does show clips from the Solar Cam Pan, the camera is detecting fine and something is stopping the alerts on the way to your phone. In that case I would check the camera’s own Notifications toggle in its settings, the main notification switch under Account in the app, and on Android 16 set the Wyze app’s battery usage to Unrestricted so the system is not putting it to sleep in the background. If the Events tab is empty too, the problem is detection rather than notifications, and on a battery cam that usually comes down to the motion sensor settings and where it is aimed.
I currently have a similar problem but notifications are intermittent and happens on all devices. The Smart Notifications only works 5-10% of the time. I have not made any changes and checked all the settings but the problem persists (for about 4 weeks now!). I am about to start a new thread with the issue, but I think this is an issue on the Wyze backend
