While attempting to setup a Wyze Pan and Wyze Cam, I have been unable to successfully open the Wyze app on my Note 10. Each time I attempt to open the app, it force closes.
I have uninstalled and reinstalled the app several times with no joy. Has anyone had a similar issue and if so, how was it resolved?
I’ve found that uninstalling this app just doesn’t really clear out all the leftover “bits.” At least with my Note 9, if I uninstall the app curiously it never asked me to log in after i reinstall it. It just opens as if I never removed it.
I have found that if I clear data (and cache by default) it forces the app to initialize, and even sends me a 2FA. So that would be my recommendation - wipe data, and then try to open the app.
